174Views11Replies
Author Options:
The leds are getting hot. Help.? Answered
I made this led array as a temporary solution to electricity outage but the leds get quite hot. Is that normal? Is there any better way to make such an array? I have attached pictures. The resistor is 100ohm.
steveastrouk
Best Answer 8 years ago
12 V and 100 Ohm resistor, and 3 white LEDs should be about right. How hot is hot ? Can you keep you fingers on them ?
Steve
frollardsteveastrouk
Answer 8 years ago
+1
...unless the battery is ridiculous
@14v and 4v leds it makes sense
@14v and 3.7v leds it needs 150 ohm
@16v and 3.7v (worst case I can imagine) 245 ohm
@author. Is it the leds getting hot or the resistors?
steveastroukfrollard
Answer 8 years ago
Its not going to STAY at 14V for long though, once its off charge.
Steve
Shariq92steveastrouk
Answer 8 years ago
Sorry i was out of country and out of available systems. The leds are hot enough that i am unable to touch them for longer than maybe 5,10 seconds. The resistors are also hot but i thought that was normal.
steveastroukShariq92
Answer 8 years ago
No, its not really normal, with that size of LED, can you measure the voltage across your resistor and the voltage across you LEDs
Steve
Answer 8 years ago
sorry cant at the moment. cause i am not at home for another week or so but from what i remember the voltage on the leds was around 3.2. around cause each led had different voltage. I think thats because i am using cheap leds. i dont remember the exact voltage on the resistor though i think it was also around 3.
Answer 8 years ago
There's something odd going on, because your numbers make perfect sense, but the overheating does not !
Steve
Answer 7 years ago
|Its not melting or anything so i guess i will just continue to use it as it is. thanks for your help. any advice if i decide to remake such a lamp??
Answer 7 years ago
Shariq,
I look very closely at your board. Did you CUT all the tracks between LEDs on the board ???
Steve
Answer 7 years ago
yes, otherwise it wouldnt work.
I checked the voltages today. With the battery at 12.2V the resistor is 2.2V and the leds at 3.3V.
Answer 7 years ago
Just that, in the picture, I can't see any track cuts.
Steve
