63Views0Replies
Author Options:
The use of gas generators in the home. Answered
Available pluses home gas generators:
* Rate per se gas generator compared with the price affordable euro GASOLINE.
* The price of fuel is lower than that of the generator on diesel or gasoline.
Available Cons:
* Gas ​​is considered the most volatile than diesel or gasoline.
* Appeal from the gas and the installation of equipment for gas processing requests for special and separate permission. Our legislation prohibited the installation of systems and gas processing equipment in the absence of a suitable plan or agreement.
* Most of all, on our market, there are gas generators made in China.
* Gas ​​generators are made on the basis of a gasoline engine, the method of adjustment of fuel injection system and fuel carburation. In accordance with this resource from the generator corresponds to the resource gasoline engine.
* Later, the acquisition of the gas generator of small capacity, the buyer is faced with a specific limitation on work: a maximum of 6 hours per day.
The resource identified by the manufacturers of gas generators, with the first glance quite broad. However, do not understand the root cause of its increase. On average, the share of gasoline engine, out of which gas engines, floats in the range up to 2000 HOURS. This common resource for the euro generator. Imagine the Chinese gasoline engine, the resource is constant. Next, suppose that the resource oposlya changing gasoline engine to natural gas will not decrease. (Our real change of cars with fuel gas indicates a reduction of the resource engine, which originally was made for 1-octane gasoline, well, and subsequently applied for another).
1 of firms offering gas generators, a guarantee in 2000, machine hours, or one year, although with the limitation, at least 6 hours per day. The appointment of such a generator is not clear. As a source of constant power, he will not do, as backup - as well as the first blackout since most 6 hours (which happens often) determines the total loss of warranty. It is reasonable to imagine that the buyer, which turned off the light of day, will not sits all day in the absence of light, zhdya coming the next day.
In general, in fact, a similar limitation on the work looks pretty amazing: It seems as clear that the miniature generator with cooling air is not able to operate around the clock. While that still causes inconvenience to cool the generator, for example, for 1 hour, and then resume his work?
In solid power installed thermal disconnector, which simply will not allow too much power to warm up, and therefore, the decision on mode of operation.
