590Views9Replies
Author Options:
Tips for painting digi camo? Answered
Can any one give me some tips on how to paint and make digi camo stencils, or direct me to where i can get some digi camo stencils cheap? Thanks.
orksecurity
orksecurity
Best Answer 10 years ago
Well, you could draw a grid and paint every square by hand.... If the edges overlap a bit, or the lines aren't quite straight, that won't make very much difference.
orksecurity
orksecurity
Answer 10 years ago
(As requested, reposting as top-level answer.)
sailor49618
sailor49618
9 years ago
I cut squares of the blue painter's tape,spray ,dry,peal's off easy.
Worked good for me.
Good luck.
~Z~
~Z~
10 years ago
Make a random comment so i can select you as best answer please.
~Z~
~Z~
10 years ago
Creative.. Might give it a try.
mettaurlover
mettaurlover
10 years ago
The best method I've seen is making paper sheets with squares cut out of them in a way that, stacked, there are no visible holes but separately there is a hole in every slot on a grid system.
~Z~
~Z~
Answer 10 years ago
I can't cut well with an exacto.
mettaurlover
mettaurlover
Answer 10 years ago
Well, then, you have a bit of a problem using that method.
~Z~
~Z~
Answer 10 years ago
Exactly. Thats why i need tips.
orksecurity
orksecurity
Answer 10 years ago
Scissors work too, you know. And practice makes better.
