192Views8Replies
Author Options:
Transparent cement? Answered
I would love to inquire more information about transparent cement. I am doing this research and I would appreciate it if someone could help me to find articles related to this topic. I would also like to know if some students are able to apply this idea and how could they manage to make this material. I read about i-light cement, but I wonder how, if possible, could this be made. I would appreciate your help!
JM1999
JM1999
7 years ago
Hello, I hope this answer helps.
I saw a documentary recently and they had cement that you could cast a shadow through.
They made it by putting glass fibers in with the premix and then they made the cement as normal, Google something like glass fibers in cement or cast a shadow through cement and you should find it.
tgferreira184
tgferreira184
7 years ago
What do you want to use the cement for? Maybe you could make it out of acrylic, perspex, polycarbonate or some other transparent plastic.
rickharris
rickharris
7 years ago
I saw a concrete block made to pass light by embedding fibre optic cable in the concrete. Unable to find the source now though.
steveastrouk
steveastrouk
7 years ago
What do you mean ? "cement" covers a multitude of meanings: Balsa "cement" and polystyrene "cement" are both clear.
HMN93
HMN93
Answer 7 years ago
By cement I mean the clinker, Portland cement used in concrete
iceng
iceng
Answer 7 years ago
Too bad ..... StarrTrek has that transparent aluminum ;-)
Seems to me you want to use glass bricks between the cement
steveastrouk
steveastrouk
Answer 7 years ago
There's no sign I can see without a lot of digging that i-light is made with OPC.
And there are LOTS of different cements for concrete too, Magnesia bases, alumina based.
Portland cement is by its nature not transparent. A resin system might bond building elements though
petercd
petercd
7 years ago
Heres the article in the daily mail.
http://www.dailymail.co.uk/sciencetech/article-134...
So, basically the cement panel has slit like holes in it that let the light through, one could possibly achieve the same effect with strips of perspex laid in a similar pattern to that which they used.
