3192Views11Replies
Author Options:
Trying to change 120 volt AC to 120 volt DC. Answered
I have the full wave rectifier rated at 400 volts and 8 amps and need to know what kind of capacitor/ voltage regulator I might need to accomplish this. I'm powering two 100 watt lights off this. Thanks!
JimZ7
JimZ7
4 years ago
So whats the answer for the original question ?
steveastrouk
steveastrouk
8 years ago
What kind of lights need a regulated supply ?
evilgenius32
evilgenius32
Answer 8 years ago
The lights are going to be put to music, so I need a DC power supply so it will work with the DC audio circut. the lights are just 120 volt incandescent floodlights
steveastrouk
steveastrouk
Answer 8 years ago
Nah. Just use phase controled AC its much easier and safer
steveastrouk
steveastrouk
Answer 8 years ago
He's asked for a regulator too.
steve
mpilchfamily
mpilchfamily
Answer 8 years ago
I read it like he thinks he can use a capacitor and/or voltage regulator to do the AC to DC conversion. If he is worried about any fluctuation in the AC input then a couple of smoothing camps with a voltage regulator isn't a bad idea. But if he is trying to power a Halogen bulb then the slight dips and spikes of 120V mains isn't going to affect the operation of the bulb so a regulator wouldn't be needed.
evilgenius32
evilgenius32
Answer 8 years ago
The voltage does have to be fairly constant for it to work.
mpilchfamily
mpilchfamily
Answer 8 years ago
OK well incandescent bulbs need AC not DC.. But if 120VDC is still needed a bridge rectifier will keep the voltage as constant as the supply voltage. Of course main power can fluxuate between 110VAC and 125VAC.
steveastrouk
steveastrouk
Answer 8 years ago
I read the / as an "and" not an "or"
rickharris
rickharris
8 years ago
Why do you nee DC @ 120 volts for lights
