2030Views5Replies
Author Options:
Turbocharger to generator conversion? Answered
Hey, I was just wondering, could we turn a turbocharger into a generator that would produce electricity as water flows into one gate and out the other?  Similar to a hydroelectric generator using the mechanical energy of flowing water through a turbine to produce electricity.
rickharris
rickharris
Best Answer 8 years ago
A lot depends on your water source - A turbo expects a high speed flow of gas so it isn't very big.
Water turbines tend to be quite big to extract maximum energy from a large volume of water rather than a fast flow.
You might be better off with a water wheel and gear up the output to drive a generator. The wheel give you slow rotation at huge torque.
steveastrouk
steveastrouk
Answer 8 years ago
Look at "impulse turbines" and the "Pelton wheel" - both high pressure low flow concepts.
ELECTRONICS3
ELECTRONICS3
3 years ago
can car turbocharger pump water if I conect 2000rpm 1kw motor to it ?!
I have old turbo from vw sharan 1.9tdi
lemonie
lemonie
8 years ago
Yes, but you'd need quite a lot of water flowing through it and at a fair pressure / head.
What have you got?
L
iceng
iceng
8 years ago
A turbocharger has special blade design made to react to a hot gas
and rotate very very fast.
Water wheels are designed to be turned by a liquid and because water
density is 62.4 lb/ft3 that is 815 times as dense as air 0.0765 lb/ft3.
The blade shape of a gas turbine cannot accept the strength and energy imparted by a liquid. It will turn in a sloshing type motion
and stop at any mechanical load where the delicate gas blades
may brake off....
Further a gas turbine electric generator would be a very high speed
and output frequency type compared to a water wheel generator.
A
bwrussell
bwrussell
8 years ago
In theory you would just need to swap the compressor for a shaft connected to a generator. The turbocharger would be like the blades on a windmill, you still need the actual generator.
In practice it all depends on how well a water stream will turn the blades, it should be but when you're using something for something other then it's intended purpose weird things can happen.
