2571Views6Replies
Author Options:
Turning a set of stairs into a heating element? Answered
Hi All,
My thought was this, I live in New England and of course there is a lot of snow and ice in the winter.  I am going to have an exterior stair that leads to the third floor of my house and keeping them snow and ice free in the winter will be  a major PITA!  I have looked at a lot of different heating products but none seem optimal.  I was thinking, after remembering small heating elements, similar to the coil you could just put into a glass of water to heat it, why couldn't I just turn the steps into a low temp heating element powered from the house's electricity?
Is this totally absurd or should it be possible?  Any ides?
TIA,
Aaron
eddiethedave
eddiethedave
2 years ago
I'm currently approaching the same problem in my new rental. Metal stairs leading to the second floor. What I've came up with so far is running say a vinyl irrigation hose under each stair with a pass at the front 180 turn then a run at the back of the step continuing up each step and once to the top running the line down and using a submergible pump in a big cooler full of anti freeze with a fish tank heater to keep the antifreeze nice and toasty. The pump would push it up from the bottom the the return line from the top just dump in back into the cooler. I'd like to have it pretty much self-contained under the stairs with just the wires sticking out and that being all that needs plugged in soon as the weather gets...poopy.. If anyone can think of any improvements or for see any problems I could run into please chime in. By the way I'm trying to keep this project as cheap as possible.
iceng
iceng
7 years ago
Placing a steep roof over your exterior stairs is immanently more practical !
I live in Reno, the gateway to magnificent skiing.
One of the ski resorts had a heavy parking lot snow load each year
They put a jet engine on a tractor platform to use exhaust to clear the snow.
IT  WORKED   MAGNIFICENTLY
For about 50 feet............................
Then the melted snow turned to an iced glaze that deepened and
successfully reflected the jet engine heat thereafter rendering the
iced lot useless for the season..
UN-intended consequences struck again  :-)
Vyger
Vyger
7 years ago
You would loose a lot of expensive heat, unless its solar or wind. You could use pipe heating tape, the stuff that prevents pipes from freezing, something like Frostex. At 3 watts per foot the power usage is going to climb pretty fast.  It is not really designed to melt ice off but rather to prevent pipes from freezing.
Did you ever think of putting a canopy over the stairs to keep them free of water/ice. Or just enclose them with plastic sheeting like a greenhouse enclosure. That type of solution would not involve wasting lots of kilowatts.
mpilchfamily
mpilchfamily
7 years ago
I think a better option would be an outdoor radiant floor heating option. Be it electric or using hot water from your water heater. But electric systems may not be a good option out doors unless you can seal them from the weather. Ideally you'll want the system embedded into or under the stairs. Most products are designed to go under a tile floor. Others are made this to go under a laminate floor.
offthedeepnd
offthedeepnd
7 years ago
Follow up, I forgot to mention, I'm sure it doesn't need to be said, but the stairs will be metal. I'm planning on using a product called faststairs for the stringers/hangers and then I have my option for the steps/treads. The steps would be the only thing that technically needed to be the heating element portion.
Thanks,
Aaron
