90Views5Replies
Author Options:
Two Airsoft Related Questions! Answered
I've seen outer shells of airsoft guns on Evike, and I was wondering... Is there an easy way to put a cheaper gun in a different shell? ALSO can anybody think of a way to put a vertical grip on a shotgun?
CapnTac
Best Answer 10 years ago
Is it possible? Yes. Is it insanely time consuming, hard, and annoying? Yes. About the vertical grip- Get a vertical grip online, then bondo/epoxy it onto the pump handle.
Fizzxwizz
10 years ago
I had a feeling that I would be that way...
FizzxwizzFizzxwizz
Answer 10 years ago
Also, do you think it would be easier if I just took a pistol and made a homemade springer? Just fill up all the other spaces with foam or whatever.
FizzxwizzFizzxwizz
Answer 10 years ago
though it would probably be cheaper to buy a springer....
CapnTacFizzxwizz
Answer 10 years ago
Trust me, it's harder than you think. Springers are a lot more complicated then most people believe. It would make more sense just to go to the store and buy a spring pistol.
