608Views3Replies
Author Options:
UK suppliers of pink/blue housing foam? Answered
I can not find any suppliers for housing foam!?
I am looking for big sheets of the foam, I am making a rowing shell and I am going to make the mould and then fiberglass.
This is the project I am going to begin https://www.instructables.com/id/Building-a-Rowing-Shell/
All comments are welcome
Thanks
steveastrouk
steveastrouk
Best Answer 10 years ago
Try a decent builders merchants, like Travis Perkins, you won't find it in B+Q or Wickes for sure.
Try asking for "blue board"
You MIGHT try "Sheffield Insulations", who have distribution round the country.
Steve
rickharris
rickharris
10 years ago
Oddly I bought Ping and Blue foam from B&Q and from Focus although they don't always stock it. Kaufman is the main producer and as Steve says almost any Builders merchant will get it for you .
Make sure it is the dense extruded polystyrene rather than the beaded white that they also sell for inter wall insulation
There is also a product called Cellotex - this is a foamed Urethane which depending on your application you will probably want to avoid.
Remember that standard polyester resin will melt the PS foam so you need to source Epoxy resin - A boat yard or chandlers may sort you out - The West system is the best known.
oscarthompson
oscarthompson
Answer 10 years ago
Thanks for you comment, I thought about the glue melting, but thankfully I have some foam glue form model making.
