108Views4Replies
Author Options:
Universal RC custom tweek Answered
I'm not sure if I post this in the right topic, so let me know if I didn't, thanks.  My kid got two rc cars a couple of xmases ago.  One of the RC controllers antenna  broke off and want to know if there is a way to make a universal rc control unit so my kid can use one controller for both cars?  Kinda  like a similar function you have for a universal remote for a tv.  Thanks for any help you can provide.
zack247
zack247
10 years ago
this is a diy site, so here is how i would do it. i would take the oscillator crystal out of the broken controller, (this is the metal can looking thing) and then desolder one leg of the original crystal. solder a two postition slide switch and have it switch between the two crystals, this should make it a "universal" remote. i can draw you up a picture if that sounds too confusing. i will wark you, the controls may be different than the original ones, since the pins on the original remotes' IC maybe assigned differently for the switches.
oldmanbeefjerky
oldmanbeefjerky
10 years ago
i too am after a similar thing where you can tune the frequency to either 27mhz or 43mhz, for a remote controll tank that drives and fires a cannon (gunpowder,copper tube, rocket starter 9v)
is there even such a thing, because when i search for one all i ever get is a multi band remote not a multi frequency
lemonie
lemonie
11 years ago
You should be able to replace the antenna, it is essentially only a piece of stiff wire.
L
crapflinger
crapflinger
11 years ago
you should go to your local RC shop...there are a lot of multi-device RC "remotes" on the market...they can transmit on different frequencies and a lot of them can even be programmed for the controlls to do different things depending on what model is being used (such as using button x and y to fire the guns on a battle ship, but when used with a model earth mover they would raise and lower the shovel)
