97Views9Replies
Author Options:
Using AC to operate a automotive 12 VDC relay Answered
My question is:  can a typical 12 vdc automotive relay be operated
(voltage across terminals 85-86)?
I am building a car from a riding lawn mower for our grandson.  I want to operate lights from the 12 VDC circuit but I need a signal voltage to actuate the relay across relay terminals 85-86.  I would like to use the existing AC powered light(s) voltage for this purpose?  Possible?
Downunder35m
Downunder35m
4 years ago
Option 1: Take a 24V relay.
Option 2: Use a SSR (Solid State Relay) as the operate on a wide range of input voltages, if it only supports DC you simly add a tiny rectifier.
mndb1971
mndb1971
4 years ago
I was wondering if I could use AC power across 85-86 with a voltage range of 24-34 VAC.
Toga_Dan
Toga_Dan
Reply 4 years ago
if you dont know if that is hot enough to fry the coil, there are 2 easy options. Risk frying it, and replace it if that happens, or throw some resistance in to reduce current (and effective V) at the coil.
Toga_Dan
Toga_Dan
4 years ago
what relay is it? What voltage is the ac
mndb1971
mndb1971
Reply 4 years ago
I will attach a photo of the relay....the AC voltage is said to range from 24-34 VAC...powers the lights on the mower.
Toga_Dan
Toga_Dan
Reply 4 years ago
is there a part number somewhere on this relay? usually step 1 is to google component specs.
mndb1971
mndb1971
4 years ago
Thanks for your assistance.
mndb1971
mndb1971
4 years ago
Well I left out the fact that I was wondering if I could use AC voltage across terminals 85-86. If the voltage is less than 12 vac, what happens?
Downunder35m
Downunder35m
4 years ago
Should be no problem as long as it is 12V or higher.
On AC the relay will most likely be less powerfull but still work as planned.
