1473Views8Replies
Author Options:
Using peltier to cool my radiator? Answered
I have this idea and wonder if it is possible and feasible.
Stick a peltier to my car radiator to generate electricity and store the electrical and then using the same peltier to cool my radiator?
doshur
doshur
10 years ago
If I remember correctly, a TEG can go up to 225 degree Celsius?
lemonie
lemonie
10 years ago
The radiator is needed for cooling, don't block it with things. Pop your thermoelectric device(es) on the exhaust system instead if you want to recover power from waste heat.
See other comment(s) though and take note.
L
steveastrouk
steveastrouk
Answer 10 years ago
JFYI Peltiers really won't like it above 150C. They melt.
Steve
lemonie
lemonie
Answer 10 years ago
I was aware that these things had limitations, but didn't know where. My thinking was - bigger heat-differential - better function. The exhaust system is long enough that you could position at the right point, but otherwise I'm with your original comment on this.
L
steveastrouk
steveastrouk
Answer 10 years ago
Volkswagen (??) I think are supposed to have a high temperature chemistry for a Peltier tech for exhaust systems. I've seen extraction levels of 600W from the exhaust pipe.
lemonie
lemonie
Answer 10 years ago
That's probably worth having, can you link me or should I go looking?
L
steveastrouk
steveastrouk
Answer 10 years ago
I JFGI, but I can only find PR releases, and the conference agenda that it was discussed at.
steveastrouk
steveastrouk
10 years ago
Unfortunately that isn't practical. A car radiator is designed to dissipate something like the same amount of energy as the engine is rated for, several kilowatts.  A Peltier cell WILL generate a limited amount of electricity at roughly 2% efficiency, but is a very poor heat pump.
Several kW worth of Peltier cells would cost many thousands of dollars, and wouldn't gain you anything.
