105Views3Replies
Author Options:
VB help, (text files)? Answered
Hi, so basically i need to create a .txt file when i press a button but it has to be named as what i entered into textbox1.text ANY HELP GUYSSS!!!!!!!!!
Clarusglassboards
Clarusglassboards
Best Answer 10 years ago
http://msdn.microsoft.com/en-us/library/5t9b5c0c%28VS.85%29.aspx should provide you with the help you need. The MSDN is very helpful with these kinds of questions. :) Good luck.
note: recommend switching from VB to C++
PREDATOR_UK
PREDATOR_UK
10 years ago
Oh and i wouldnt switch to c++ unless you want to do proper hard coding and windows programming.
PREDATOR_UK
PREDATOR_UK
10 years ago
To easily create a text file we create something called a file stream. The filestream will then be assigned the of creating your file. We do this by using this code:
Dim fs as system.io.filestream ' Open the filestream
fs = system.io.fie.create("C:\Users\...") ' Or whatever path you want
fs.close ' Remember this because otherwise it can cause problems
Copy the above code straight in.
Regards,
PRED
