92Views5Replies
Author Options:
VEHICLE RUST? Answered
I have a 1980 Qld ambulance - which has a lot of rust in the floor - walls and roof of the cabin - I was wondering if anyone had any tips for taking the rust out apart from using oxy and jam cans.
Cheers
blkhawk
blkhawk
8 years ago
Remove all the rust. Use sheet metal and rivets to cover any holes. Apply Bondo® and, sand it when hardens. Prime and paint to finish. You can coat the bottom with roofing tar. You have some work ahead of you!
KNOBPOLISHER
KNOBPOLISHER
Answer 8 years ago
Thank you for your comments
Cheers
PS I have now attached a photo
blkhawk
blkhawk
Answer 8 years ago
It does not look like the rust "ate" through the metal so, try sanding the rust to the bare metal. There are power drill attachments that will help you speed up the sanding process. Apply a primer and paint. Use spray paint that matches the color of the rest of the car. You will see a difference in gloss between the new paint and the rest of the ambulance. Remember that the old paint had faded withstanding weather for so many years. Don't be surprise if you end up painting the whole thing.
KNOBPOLISHER
KNOBPOLISHER
Answer 8 years ago
mole1
mole1
8 years ago
Very cool! It's going to be so awesome when you're done!
In case you haven't run into it before, for little rust problems, there is a product called Rust Reformer or Rust Converter that goes on as a milky liquid and turns black when it meets rust. It stops rust from continuing and bonds with it to create a protective coat on the metal. It's a chemical reaction. Great stuff.
