3841Views10Replies
Author Options:
VFD voltage and current needed Answered
I've a Futaba 4-LT-16 9L big VFD display. Unfortunately I'm not able to find the datasheet or exact details about it.
Maybe I could contact Futaba...
The only informations I found are these two schematics
https://revspace.nl/old/IMG_2239.JPG (but it doesn't match with the 4-LT-16 display)
https://revspace.nl/old/IMG_2240.JPG (not very useful to me)
from this page and this video from the same page.
Could someone help me?
Are there typical voltage and current for the filament (I think it depends from the length and the display dimension)? What about the grid voltage?
Thanks!
joelr7
7 months ago
Did you ever get this working?
I have a similar display: 5-LT-43B1
It would be cool to know if you got yours working.
joelr7joelr7
Reply 7 months ago
I just got mine working on ~3v across the filaments and ~20v across the grid and elements.
I found this helpful for basic hook up tactics: https://hackaday.io/project/29339-driving-vacuum-f...
and then tried raising the voltages until it began to light. If the filamant is over driven, it begins to glow like a dim light bulb, this indicates over voltage.
arief.adha
4 years ago
this may help. but not in English, i use google translate
http://www.elektroda.pl/rtvforum/topic658364.html
devicemodder
5 years ago
anodes and grids are around 20-30v
steveastrouk
5 years ago
Typical filament current ~70mA on 3V, the display needs -18V DC to light the segments.
andrea biffisteveastrouk
Answer 5 years ago
Thanks Steve, I'll give it a try! Did you find these parameters on the datasheet of the chip?
steveastroukandrea biffi
Answer 5 years ago
No, I found a power supply designed for the part. I verified the numbers against the first data sheet i pointed out to you.
steveastrouk
5 years ago
I found thus
http://www.datasheetarchive.com/dl/Scans-005/Scans-00107096.pdf
...which is a datasheet for a Hitachi VFD clock chip, the application circuit shows the chip connected to the Futaba 4-LT16 display.
Answer 5 years ago
Thanks! I didn't find it before... Unfortunately it seems to be not useful in determine voltage and current of display..
