281Views8Replies
Author Options:
VLSI testing ? Answered
I am looking some information for Vlsi testing
what is Design for testability
what is Built-in self test
Tags:vlsi
vead
vead
Answer 6 years ago
Ok I am reading but I have some doubt
can someone help to understand this topics
scan is techniques used in design for testing
Q1 . how does vlsi circuit scan
I mean we need software tool or test equipment to scan VLSI circuit ?
Q2 when does we scan circuit after fabrication or before fabrication ?
steveastrouk
steveastrouk
Answer 6 years ago
You need VLSI scanning hardware, often via the JTAG port to do it. You scan AFTER fabrication - else what are you testing ?
vead
vead
Answer 6 years ago
ok tanks for help
design for testability is process ensure that design has enough
observability and controllability to provide for complete and efficient
test
built in self test - capability of circuit to test itself
built in self test circuitry incorporated within chip for self testing
test vector ---> original circuit & self test circuitry --> output response
scan design - scan is technique used in design for testing
test vector ---> original circuit & scan circuitry --> output response
Q- how does test vector generate for built in self and scan design
I think for scan we use ATPG to generate tset vector
does we use ATPG for built in self test
Q how does design make testable ?
I think we add some flip flop and mux to make testable design
Q can someone little bit how does circuit make controllable and observable?
steveastrouk
steveastrouk
Answer 6 years ago
steveastrouk
steveastrouk
Answer 6 years ago
vead
vead
6 years ago
Fault may occur anytime
- Design
- Process
- Package
circuit design
functional design
structural design
layout design
when we design circuit on software , error can be determine by the simulation
vlsi circuit contain additional test circuit like fault modeling
stuck at faults
Bridging faults
Transistor stuck-open faults
Delay faults
error can be determine by fault simulation
we can test circuit to determine fault
Q1 what is test generation ?
Q2 scan is technique used in design for testing ?
Q3 built in self test
built in self test method that allow circuit to test their own operation
__________________
rickharris
rickharris
6 years ago
Oddly, I would think both terms are self explanatory.
http://en.wikipedia.org/wiki/Design_for_testing
http://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&s...
Testing any system is invariably a test against the original design specification.
The simple question is does the item do what it is supposed to do. The hard part is having a sufficiently detailed document that actually defines what the item is supposed to do.
Of course with electronic systems it may be necessary to place boundaries around a system element so that external factors do not expand the test field until it gets out of hand.
In general the majority of systems and sub systems are often tested in terms of their inputs and the corresponding outputs. With numerous inputs the testing for combinational problems can quickly get out of hand - this is a case for breaking the system into even smaller sub systems.
In an ideal situation every sub system should have a single function so that its operation can be easily confirmed and multiplex interactions are avoided.
It can be much easier to see where the combinational error is if you are confident in the operation of the individual parts.
I might note that with software this simple procedure is rarely followed. Hence software development tends to be late, none of limited functionality or well over budget, or indeed a combination of all 3.
