272Views18Replies
Author Options:
Variables in a batch file? Answered
Im working with Vista SP1 and experimenting with batch files, i came up with a problem so i'd see what you thought. This is the code i was using:
:top
@echo off
color 0a
Title Experiment by Me
echo -------------------------------------
echo Type a letter between a and d.
set /p letter=
if %letter%=a
goto a
:a
echo This is the result of entering A
pause>nul
What happens is that the box closes after you enter your letter and press enter, i dont have any more results (i.e. where it says :a) because i found it didnt work
Prof. Pickle
Prof. Pickle
8 years ago
I improved your code:
:top
cls
@echo off
color 0a
set /p letter=
If %letter%==a goto a
If %letter%==b goto b
If %letter%==c goto c
If %letter%==d goto d
goto please
:a
cls
pause>nul
goto top
:please
cls
color 04
echo Oooops, you typed a key that was not an option.
echo.
echo Press any key to go back to the top
pause > nul
goto top
NachoMahma
NachoMahma
12 years ago
. Try this:
...set /p letter=Type a letter between a and d, then press ENTER:if %letter%=a goto ltra:ltra...
Pawn_of_Prophecy
Pawn_of_Prophecy
Answer 12 years ago
Nope, this doesnt work, it just puts "Type a letter between a and d, then press ENTER:" below the line i made but still closes the box when you press your letter and press enter. thanks for trying though
NachoMahma
NachoMahma
Answer 12 years ago
. Try stopping after the if - you may not be getting what you think you are.
...if %letter%=a goto ltraecho You typed %letter%pause:ltra...
Pawn_of_Prophecy
Pawn_of_Prophecy
Answer 12 years ago
No, i've already tried this, it lets you enter the letter, you press enter and it still closes the box
dsman195276
dsman195276
Answer 12 years ago
try this:
echo type a letter between A and D
set /p letter=
if %letter%==A then (
echo this is what happens when you type A
you need parenthesis on your if statement. without them it stops at that if line, and does not execute the goto line.
TATcreator
TATcreator
Answer 11 years ago
Wrong. You must put two = signs, not one.
TheBatchies
TheBatchies
Answer 11 years ago
1. Uhhhh... No, I think. Not when you're setting the variable with the /p command, but I could be wrong.
2. JUST USE STINKING EQU!!
Pawn_of_Prophecy
Pawn_of_Prophecy
Answer 12 years ago
This is closer, but now it echos this is what happens when you type A regardless of what you type
dsman195276
dsman195276
Answer 12 years ago
set /p letter=
if %letter%==A (
the "then" was not needed ;-)
TheBatchies
TheBatchies
11 years ago
@echo off
:top
color 0a
choice /n /c:abcd
if errorlevel d goto d
if errorlevel c goto c
if errorlevel b goto b
if errorlevel a goto a
:a
pause>nul
:b
echo This is the result of entering B
pause>nul
:c
echo This is the result of entering C
pause>nul
:d
echo This is the result of entering D
pause>nul
Arbitror
Arbitror
11 years ago
:top
@echo off
color 0a
set /p letter=
if %letter%==a goto a
goto end
:a
pause>nul
:end
This should solve your problem. =) Notice what lines I changed. Make sure not to miss the double "="!
Arbitror
Arbitror
Answer 11 years ago
Soo...
Did it work for you?
TATcreator
TATcreator
11 years ago
In your script, you wrote
if %letter%=a
You should have wrote
if %letter%==a
with two = signs
Arbitror
Arbitror
Answer 11 years ago
But still, then any letter he entered would echo "This is the result of entering A". Read my above comment!
TATcreator
TATcreator
Answer 11 years ago
True, just giving compatibility/stability advice.
TATcreator
TATcreator
Answer 11 years ago
He doesn't need it...
