77Views8Replies
Author Options:
Vendor for lower power LEDs. Lower the better.? Answered
I'm working on a prop mod for poops and giggles. I'm trying to make LEDs run on a potato battery. May be impossible, but I'mma find out.
I need the lowest power LEDs I can find
iceng
8 years ago
Here is how to do super potato.
Do let me know if you try it and how long it powers the LED ?? A
steveastrouk
8 years ago
Look for high efficiency red LEDs, and limit the current to 1mA or perhaps less, you won't get much light but you'll get some. You'll still need to generate more than 1.2V to drive them - I've no idea what voltage and current you can expect from a potato battery.....
Steve
Dinkum Thinkumsteveastrouk
Answer 8 years ago
Thanks for the feedback guys! I had just remembered I had posted it here. I don't need light to illuminate, just to suggest glowing really. Next part is to see if I can supercharge one potato do do it...
Thanks!
-Dinkum
iceng
8 years ago
Google is amazing......  A
steveastroukiceng
Answer 8 years ago
Hence the term Pot-ential.....
I wonder if there is > 1.2 V there ?
Steve
icengsteveastrouk
Answer 8 years ago
Only this actual.
Looks like a cut up sandwich ( Large area plates for current )
then banded together for output to the lowest forward voltage
Red LED as you  First  Foretold.
You and I would have surely used the colored clip cords correctly :-D
A
aelias36iceng
Answer 8 years ago
Adding to that, you can use thick copper wire and galvanized nails for the electrodes/terminals, and make sure to connect the copper terminal to the longer lead of the LED (positive), while the zinc terminal to the lead below the "dent" in the lip of the LED (negative.)
