120Views7Replies
Author Options:
Very small microcontroller Arduino rogrammable? Answered
Hey all!
I really need some help! Ok, so I want to make a very small circuit and put it in my watch, but I don't have any microcontollers small enough tor with enough pins. I want around 16-20 I/O pins but I want it to be in a very small package. Like the flat square ones with 10 pins, or the long thin rectangular ones. It also has to be able to be programmed using my Arduino.
Several suggestions and help on how to find my own would be a great help!
~AJ
verence
verence
6 years ago
Getting a µC in a very small package is not a problem, for example, see page 637 of the ATmega µC. 32 pins and only 5x5mm small.
The question is: Can you handle a device that small? The pad pitch is 0.5mm.
You can et almost any popular µC in very small packages. In fact, some interesting devices are only made in packages that are too small to be handleable by hobbyists.
HavocRC
HavocRC
Reply 6 years ago
Yeah but not that small. I found something like this, that may work.
ATTINY26L-8SU
Its small enough to fit in my project, has enough pins but big enough so that I can solder it to a PCB.
verence
verence
Reply 6 years ago
Yep, that looks reasonable for a hobby project.
But hey, you said 'very small' - I gave you small! :-) The smallest µC I ever saw was 2x2mm and had 16 ball grid contacts on the bottom. Was not allowed to use it in a design - we couldn't find someone to manufacture the PCB reliably and cost effectively.
The web sites of the manufacturers have quite good selectors like here.
To find the dimensions of the packages check the data sheets. Those data sheets are an invaluable (and the most definitive) source of anything you want to know about the devices.
HavocRC
HavocRC
Reply 6 years ago
After a bunch of searching I decided to try the Attiny2313 in the smaller package, the same as shown in the picture (I forgot the actually package name). Since I already have the bigger 2313 I figured it would be easy for me to program it.
verence
verence
Reply 6 years ago
Yes. The function is the same regardless of the package (99.99% of the time, sigh..). That way you can test your design and code on a breadboard with the bigger IC and design a PCB for the slimmed down version.
Good Luck and post an Instructable when you're done.
HavocRC
HavocRC
Reply 6 years ago
Alrighty thanks! Okaydokey I might, it if amounts to anything!
mh76dk
mh76dk
6 years ago
You can get the same atmega as on http://arduino.cc/en/Main/ArduinoBoardUnoSMD But it is not an easy part to solder. Assuming you already have an Arduino Uno there is this instructable on programming the device
https://www.instructables.com/id/Rapid-programming-... Which uses an adaptor.
You might also be able to find a smaller device on this list http://playground.arduino.cc/Main/ArduinoOnOtherA... but they might not have the same features (and the page warns that they are not well documented)
