4380Views6Replies
Author Options:
Voltage controlled low pass filter with resonance schematics, anyone? Answered
Can anyone provide a link or schematic for an audio low-pass filter with resonance, with the low pass frequency able to be controlled with varying voltage? I'm hoping to make something like the moogerfooger, but I don't need an envelope filter.
aelias36
aelias36
Answer 9 years ago
Great! That's exactly what I was looking for. Not exactly small on parts, but it sounds great and is *much* cheaper than buying one. Any recommendation on how to get the -/+ 12v? I'll just use a computer PSU for breadboarding, but if i need to put it in an enclosure, and I need a good way to power it.
steveastrouk
steveastrouk
Answer 9 years ago
Its dead easy.
Get a mains transformer preferably centre tapped. Tie the tap to ground. Put a bridge rectifier across the other two terminals. Take positive juice off the positive terminal and negative juice off the negative terminal.
Connect a nice fat (try 1000uF) capacitor across the positve supply to ground, and another from the negative supply to ground.
Wire a 7812 regulator from the positive supply and a 7912 regulator from the negative.
Make sure you FUSE the input to the transformer - and I usually fuse the outputs too, using slo-blo fuses.
aelias36
aelias36
Answer 9 years ago
Thanks!
akanksha19
akanksha19
8 years ago
do you have any idea of design of cerberus filter ????
steveastrouk
steveastrouk
9 years ago
Do you mean like this ?
http://fluxmonkey.com/electronoize/opampFilter.htm
