219Views1Replies
Author Options:
Wanting to make a RGB Lightsaber with Rpi Zero? Answered
Hello I am hoping to learn electronics to make a Multi Colour changing Light saber with a Raspberry Pi Zero as the brains of the system and using the following parts
A Rotary Encoder = to help with changing the colours
A Tri-Accelometer = to use for location info for blade sounds
speaker = playing the sounds
RGB LED = Light for the saber
Clash Sensor = for when the blade is hit
1 Button = Power switch
1 Button = Selector Switch
Battery Pack of 4 18650 batterys
wire to link every thing togeather
I have seen that on Mag pi Issue 42 they made a LED Lightsaber https://www.raspberrypi.org/magpi/issues/42/ which I am using as the base of what I want to do but I am not sure how to do it and weather it needs more parts
the Blade would change when you turn the encoder then press the Selector switch to lock it to that colour or pressing the selector starts the ability to change colour
randofo
Best Answer 2 years ago
That is way outside the scope of this class. You may want to check on the Raspberry Pi class launching soon.
