18805Views7Replies
Author Options:
Washing machine motor wiring? Answered
i just found a washing machine on the road. when i dismantled it. there was only the motor no capacitor found.
 on the motor there is no description or labels.
there is 3 wires out of it.
i want to run this motor at full speed whichever direction it rotates. just want it to run at maximum speed.
the simplest way is the better.
Wires on it
Blue WIre
Red Wire
Yellow wire
i have the capacitor that i got from another motor.
just need to know how to wire it.
 connect it to the mains
run at maximum power without burning it.
the motor is brushless.
Vyger
Vyger
Best Answer 10 years ago
Run whatever numbers are on it through Google and try and find a schematic for it. Since some motors require starter circuits you need to know what is missing before you try plugging it in.
Andale_The_Great
Andale_The_Great
10 years ago
Being red/blue/yellow I gotta wonder if one's a speed sensor.
Red probably hot, might be 110 but sometimes washers have transformers (i believe).
Yellow would be my guess for a speed sensor.
Blue would likely be a 'switched' wire (ie: on/off) in my opinion.
Easiest solution to my mind would be to put a multimeter to it (reb/blue first IMO) then spin the dude. DC motors supposedly work as generators too, so i'm told, I've never had anything to try it with.
ARJOON
ARJOON
Answer 10 years ago
tried it with a capacitor and now works
the best way to tell is just trial and error. with only 3 wires this shouldn't be a problem. try red ac supply and blue return, then vise versa, red supply yellow return, etc etc, then try the same thing with a 12volt battery.
steveastrouk
steveastrouk
10 years ago
Any signs of switchgear on the armature ?
Steve
ARJOON
ARJOON
Answer 10 years ago
nothing. just 3 wires out.
