777Views5Replies
Author Options:
Waterproofing RC servo connections? Answered
Hi everyone. I have used epoxy to waterproof my RC receivers. I have thought that there is no need to waterproof the connections because it is only 6V and not enough to corrode the connectors. I still want to be able to swap my receivers between models. I have splashed through puddles before but not completely submersed it in water.
So is there any reason that I should be waterproofing these connectors? Or is the voltage not enough to cause any problems?
Thanks, David.
David97
David97
7 years ago
Has anyone got a good idea for waterproofing the buttons? I was thinking of using silicone glue but not sure if the epoxy will bond to it. I can either put glue over the button and then epoxy around it or do it the other way around. Not sure If it will bond between the silicone and epoxy.
steveastrouk
steveastrouk
7 years ago
If the connectors are gold flashed, they barely need protecting.
David97
David97
Answer 7 years ago
Ok thanks, probably a good idea to replace my servo leads. I have some gold pins that I will swap before waterproofing a new receiver.
mpilchfamily
mpilchfamily
7 years ago
Vaseline or other petroleum jelly is great for water proofing connections.
benmurton
benmurton
7 years ago
It would be worth doing something like covering them in grease, to keep water out, then you can still remove them.
