297Views3Replies
What are the brightest RGB LEDs. How could I string 24 for them together with out wall power?
Build a light design. 24 RGB LEDs in a square. 8 inch circles. Frosted Plexiglass. I need this thing to roll on coasters though so I was hoping to have a strong battery that I could light these with and then recharge the battery after wards like a jetski battery. Thanks new to electricity.
8 years ago
16 is a square (4x4)
25 is a square (5x5)
...24 is not a good square :(
If you want the ability to program/change the leds, I recommend the shiftbright module. They allow you to string them together daisy chained and then input (shift) instructions down the line with a microcontroller (such as arduino, very well supported).
If you know nothing of what you're doing to start with, go with a ready-made solution as it will save you a LOT of hassle.
http://macetech.com/blog/node/54
They are 4.99 usd each, but drop to 3.99 each if you buy 25. (totally reasonable price especially for how much time they'll save, and the cost of the parts/board/assembly/configuration of your own stuff)
Answer 8 years ago
*and they're 5-8 volts compatible, so an RC toy battery 7.2v is common and inexpensive/quickly interchangable.
If the 60mA version is too small, there is the 300mA MegaBrite http://macetech.com/store/index.php?main_page=product_info&cPath=1&products_id=9
8 bucks each in quantity, but ridiculously brighter.
8 years ago
The brightest is mush controlled by how much your willing to spend.
Have a search through so electrical suppliers.
battery supply is possible - These sites may help a lot.
http://led.linear1.org/led.wiz
http://led.linear1.org/1led.wiz
http://ledcalculator.net/
It's not possible to give any real figures now because we don't at this stage know what LEDs your going to use.
