246Views4Replies
What are the different kinds of triggers used in knex guns?
Please tell me the different types of triggers used in knex guns and include an example.
Best Answer 11 years ago
an improvement on logic boy's answer:
pin type:
block trigger:https://www.instructables.com/id/K_NEX-GUN/
true trigger:https://www.instructables.com/id/The_El_Diablo_Assualt_Pistol_R_45/
sear trigger:https://www.instructables.com/id/SR_commado_v1/
slingshot type:
high-tension:https://www.instructables.com/id/knex_smallish_cannon/
sniper (light sear):https://www.instructables.com/id/SR_V2/
tomboyrme trigger (specialised sear):https://www.instructables.com/id/Knex-carbine/
ratchet:https://www.instructables.com/id/The_Sipriani_Rifle/
counter-tension:https://www.instructables.com/id/Knex-light-crossbow/
and if you want to be picky, the trigger on the corner crossbow is considered a high tension sear trigger. and the counter-tension trigger i showed is an outer mech, the other ones are inner-mechanisms.
11 years ago
Ok lets see.
for pin type guns:
Block trigger-Killerk's https://www.instructables.com/id/K_NEX-GUN/
True trigger-The jamalam's https://www.instructables.com/id/Storm-221-V24-Battle-Sniper/
Sear trigger-DJ Radio's https://www.instructables.com/id/SR_commado_v1/
for slingshots its a bit harder
Ratchet system-Viccie.B 1993's https://www.instructables.com/id/The_Sipriani_Rifle/
No real name but Y connector triggers-Viccie.B 1993's https://www.instructables.com/id/The_White_Tiger_V2_Rifle/
there are others but most of them atre one offs
11 years ago
True triggers ------TBAP
Block triggers------knex cannon
Sear triggers-------Sipriani
Answer 11 years ago
Sipriani does not have a sear trigger. It has a slingshot ratchet trigger.
