3245Views4Replies
Author Options:
What are these flexible moldable metal coils called and where do I get them? Answered
Hello guys,
I am doing a project for a laser show and I need something flexible and moldable to holdup the lasers in a specific positions.
I am looking for something like a flexible tube. Something like this.
http://www.ladiesgadgets.com/flexible-game-console-stand-models-from-brando/
http://www.techfresh.net/naja-king-flexible-stand-holds-ipods-or-iphone/
You see that phone holder attached to that metal bendable and moldable coil thing? I need that.
I need to know what they're called and where I can find them, and hopefully in different lengths and thicknesses.
Thanks!
Burf
Burf
Best Answer 9 years ago
Google for "flexible gooseneck tubing"
You can get it in chrome, black or multi-color plastic coatings, in various lengths.
cammcmillen
cammcmillen
Answer 9 years ago
aaaa Gooseneck.
Thank you good sir
deston1
deston1
5 years ago
can you "gut" the tubing so wires can be fed through it?
richfiddler11
richfiddler11
8 years ago
I would also like to find a source of this small diameter (1/8"-1/4") flexible gooseneck tubing for a mini microphone mounting application, but it is hard to find in small quantities.
If you don't need it to be hollow, aluminum 'armature' wire makes a good material for flexible arms. Armature wire is used by sculptors to build a frame to strengthen clay sculptures (think about sculpting a horse). It can be found at some art supply stores and comes in a variety of diameters.
Here is one online supplier:
http://www.sculpt.com/catalog_98/CLAYTOOLS/wire.htm
Heat shrink tubing, aquarium air tubing or other flexible tubing can be used to cover the aluminum. For example, many of the suction cup flexible gps/phone/gadget mounts used in cars have a very heavy gauge aluminum wire inside a black plastic corrugated tube.
Finally, Heavy gauge (12 ga or lower) solid copper electrical wire can also work for light applications. This has the advantage of solder as a connection option, since solder adheres well to copper (aluminum, not so much).
cammcmillen
cammcmillen
9 years ago
No actually I don't want the stand, I'm only looking for the flexible tube or pipe that its hooked up to.
Thanks
Kiteman
Kiteman
9 years ago
Working backwards from the links you gave, you can get them fromhere.
You may also want to consider one of the Gorillapod range.
