108Views2Replies
Author Options:
What can I connect to a cylindrical CD case to make it spin? Answered
I need to make something that will feed my cats for one meal. I want to use one of those cylindrical CD cases that hold 50 or so CDs with a hole in the side to dispense kibble. I'll just be connecting the motor to a normal light timer. The only thing I don't know is how strong of a motor I would need to turn it with about 1/2 cup of cat food while it's on its side. I don't think a dinky clock motor would do it, any ideas where to scavenge something stronger? No, I don't really want to make the VCR feeder, too complex for what I need.
Re-design
Re-design
11 years ago
It's not going to take much to turn the feeder if you have it mounted well and it doesn't drag. Any small gear motor that will move it a couple of rpm will work great. I would put limit switches so that it will turn 1/4 of a revolution and stop. Or maybe you need it to turn 1/2 rev. to work your feeder. One of those cheap power screw drivers (not the drills) would be easy to hack to start and stop easily. You could run it off a wall wart power supply and then you could use the appliance timer. The drill would even be easy to connect to the axle. Good luck.
