64Views2Replies
Author Options:
What can be the problem with this circuit? Answered
I built this Opto Sensitive Dimmer's dimmer part first just one led the Orange is light. but can be the problem? I built this on a test board so sorry for the soldering.
randofo
randofo
2 years ago
I assume it worked on a breadboard first?
I see some potentially bridged connections, lifted pads, and possible cold solder joints. It's hard to debug from this picture because there are honestly a lot of potential failure points. Not to mention, it might not even be the soldering at all. You could potentially have overheated one of the parts (it takes a lot of heat to lift a pad), or you could have shorted something if the soldering is incorrect.
Since these don't look like expensive components, I think it might be easier to start over (if possible), work very slowly, and try to keep the soldering very clean.
rickharris
rickharris
2 years ago
Your soldering leaves much to be desired. You need to check that you don't have any bridges across the tracks. Double, triple check your circuit is assembled correctly.
