95Views17Replies
Author Options:
What can i use this for/ how can i use it? Answered
I have several of these, they are used in cheap alarms and games to make beeps. How can i make it beep, or do other things, here is the picture.
https://www.instructables.com/file/F8N9STRFUPUPDYY/
I also have some that are completely flat, how do i use those?
frollard
frollard
Answer 11 years ago
the completely flat ones can be used as a sensor for a drum pad (like rock band)
XOIIO
XOIIO
Answer 11 years ago
So, if i hook it up like a switch, and hit it, it will breifly turn on a LED, or something else?
frollard
frollard
Answer 11 years ago
negatory good sir - you'd hook it up like...a piezo :D a piezo element puts out electricity (in EXTREMELY minute quantities) when they are impacted - you'd need a circuit similar to an audio amplifier to boost the power from near zero to 'detectable' - then use that circuit to trigger as a 'switch'. Sadly they're not a very easy 'drop in' component.
XOIIO
XOIIO
Answer 11 years ago
OK, maybe I'll use them to decorate something, maybe make a mini robot out of scraps.
frollard
frollard
Answer 11 years ago
really its not too tough - it only needs like 2 transistors, a capacitor, and an uuber resistor - so the tiny pulse from the piezo triggers the transistor, and the transistor triggers the other transistor. You can get a digital pulse out to use as a tap sensor.
XOIIO
XOIIO
Answer 11 years ago
Is there an instructable to do that?
frollard
frollard
Answer 11 years ago
Not yet :)
XOIIO
XOIIO
Answer 11 years ago
Hmmm, that gives me an idea....
lemonie
lemonie
Answer 11 years ago
That is a flat one I think, but has a resonance chamber attached to it. Being metal I wouldn't recommend trying to remove it (they can break fairly easily, I know...) L
frollard
frollard
Answer 11 years ago
thats what I mean - the chamber might cause some loss in detecting impacts...
lemonie
lemonie
Answer 11 years ago
Yes I agree. I've broken these trying to take 'em apart... L
XOIIO
XOIIO
Answer 11 years ago
Ummm... your link appears to not exist?
lemonie
lemonie
Answer 11 years ago
I made a tiny error on the formatting - see the ) is in the hyperlink? It can't find the document.html)
If you remove the ) it gives you an example, but there are lots. "sine wave oscillator" might be a good search term
L
XOIIO
XOIIO
Answer 11 years ago
oh, thanks.
Dr.Bill
Dr.Bill
11 years ago
you can use 2 to make a pair of head phones for a Crystal Radio Set.
XOIIO
XOIIO
Answer 11 years ago
Really, that would be interesting, now i just need to male a crystal radio set...
