311Views11Replies
Author Options:
What could make my antique table fan run backwards? Answered
I bought an antique hunter table fan at an auction. The power cord was missing so I replaced it. When I turn it on now it runs but it sucks air rather than blowing it. Can anyone tell me what the problem might be?
liquidhandwash
liquidhandwash
3 years ago
Some induction motors get a bit confused, something to do with the residue magnetism in the core. Spin the fan the correct direction, with your finger then turn it on.
EddieP21
EddieP21
Answer 3 years ago
Thanks, I'll give that a try as soon as I get it back together.
iceng
iceng
Answer 3 years ago
+1
iceng
iceng
3 years ago
I see a capacitor and a coil inductor that could deal with speed setting or lag / lead MMF ( Magnto Motive Force )... There is a loose red wire with a spade connector that presumably goes to the capacitor. The four wire nuts look recent. If you worry about brittle insulation slide shrink tube across the wires...
EddieP21
EddieP21
3 years ago
Thanks for all the suggestions. Here are some photos. Some of the wires are pretty brittle so I guess I need to rewire everything once I get it working right.
steveastrouk
steveastrouk
3 years ago
Show us a picture of all the internal wiring. If there's a Capacitor, there are usually three wires, with one on the cap going to one wire on its own, the other cap wire + another wire going to live, and the final wire to neutral. Swap any pair.
There is usually a ground wire. Make sure THAT stays on its own, and grounded !!!
Josehf Murchison
Josehf Murchison
3 years ago
Sounds like the brushes have been reversed. On a AC segmented commutator to reverse the motor you reverse the leads to the brushes.
EddieP21
EddieP21
Answer 3 years ago
Thanks for the suggestion Josehf. I'm not sure how to check that but there are two wires going to a capacitor. One red and one black. Can I reverse them? Will that do anything?
Josehf Murchison
Josehf Murchison
Answer 3 years ago
That sounds like a starting capacitor.
Is the motor an induction motor?
If it is the capacitor is an AC capacitor and switching the wires won't do anything.
rickharris
rickharris
3 years ago
Been dismantled and the fan put on backwards would be my first port of call.
EddieP21
EddieP21
Answer 3 years ago
Thanks for the suggestion. I took the blade off and it can only go on one way but it was a good idea.
Josehf Murchison
Josehf Murchison
Answer 3 years ago
You flip a fan blade over the pitch is the same RicK
