1565Views19Replies
Author Options:
What do I do now? Answered
Had an old laptop that had been rode hard and put away wet, given to me. It had a broken LCD, well I'm not one to just throw something away because it is broken, na, I visit "instructables.com" and find a use for it.
It was kind of neat to examine the LCD assembly. Question is, there are so many neat things in there and I don't have the foggest idea of what I can do with them. Items such as:
1. The backlight assembly, aprox 1/16 dia floresent lamp about 10" long with controlor board. How can you determine the voltage, input and output points and such. Sure would be a shame to "blow" this thing using the "by guess and by golly" method to make it work. My guess is it would make a neat light for a picture or something like that.
2. Two sheets of simi-opeic plastic which appear to be horzontial and vertical orienated somethings.
3. A plastic sheet with at least 34,542 dots on it (that's where I quit counting). This alone would make a good "dot-to-dot" playing board for some "very little people". Need a better idea of what to use it for.
Any ideas of something these items would be usefull for?
Mahmoud Alaa
Mahmoud Alaa
8 years ago
you should replace the broken lcd with a touch lcd and but the lcd on the keyboard and and secure it with a tape and turn it in to an tablet
siamonsez
siamonsez
10 years ago
If the battery still works you might be able to salvage/replace the electronics between where the chord plugs in and the battery terminals. You might not be able to tell if the battery still functions until you have already done a bit of work, but it it does you could cut the part of the case that houses/holds the battery and have yourself a nice portable power source for some other project.
awz123
awz123
10 years ago
If this was my laptop i would start by scrapping the parts (remove the ram, hardrive) and insert them into my pc. Then I would go about the remaining parts by driving over them with my pick up truck... but thats just me. (the parts would serve your computer well and the demolition of the laptop would bring enjoyment to you)
northernmagnet
northernmagnet
10 years ago
hmm... try going to a localy owned craft store and show them what you have and make sure its a single person owner never franshised and ask what they would do
Lowney
Lowney
10 years ago
I can't really suggest anything for the individual pieces, but looking at the "Dead Computer Contest" winners will be a good start! Just instructables search "Dead computer Contest"
Emiliano Valencia
Emiliano Valencia
10 years ago
well, you can go outside and collect things to craft something
larystoy
larystoy
Answer 11 years ago
After getting the computer apart it appeared to have gotten dirty and wet, like having been left outside or something. Everything was corroded and rusty, even I didn't think there was anything salvageable in it.
Thanks for the input.
larystoy
techturtle2
techturtle2
Answer 10 years ago
You can get rid of the rust with Coca-Cola and Qtips. It worked wonders for me.
skittlespider
skittlespider
Answer 11 years ago
Yeah, if it is rusty, it's too late.  The laptop I used for my project did get wet and dirty once though.  (Luckily it was off at the time, so no shorts)
My dorm room roof leaked all over it.  I took it apart and cleaned everything with alcohol and q-tips.  But luckily I got it all cleaned before rust could happen.  I live in Louisiana, so rust can form very quickly!
PieMaster777
PieMaster777
10 years ago
if u could find an old NES you could build this :D https://www.instructables.com/id/How-to-build-a-Nintendo-arcade/
Bert99
Bert99
10 years ago
RECYCLE! GO GREEN!
Crakur
Crakur
11 years ago
"rode hard and put away wet" I havent heard that in years.
I personally would use the MB for something artistic, I saw a guy that had a MB encased in some kind of plastic and made into a clip board, that was cool
knex_mepalm
knex_mepalm
11 years ago
 The plastic sheet have transparent dots? if you can you can make one of those etch-a-sketch dot-to-dot or for note taking, you need some magnetic pieces for that though, recontact me fr more info.
acidbass
acidbass
11 years ago
 you could hook an external monitor or use the old laptop as a new laptop stand or some cool sh*t like that
bowmaster
bowmaster
11 years ago
Could you use the sheet with all the holes in it as a curcuit board?
larystoy
larystoy
Answer 11 years ago
Darn, they weren’t holes, just "dots". It appears as some sort of grid pixels. Of course if you would like to drill the holes, I will forward the sheet of plastic to you.
The other two sheets appear to be polarized because I was wearing a pair of corduroy slacks one day and noticed I could see the pattern only in one direction when I turned the material.
The rest of the computer was pretty well trashed, the 6 Gig (WOW) HD had a loose part rattling around inside. The CD was only a 24X (Probably take Belgazery's, and Khaos94's suggestion and use parts from it to make the Lazer thingy).
Guess it's on to the next project with this one, thanks to all.
Larystoy
khaos94
khaos94
11 years ago
Well i don't know if your planning to chop the keyboard half of the laptop too but if you do you can turn a dvd writer into a fairly powerful burning laser. I fitted one into one of those tiny mag light torches and it fit perfectly.
