234Views11Replies
Author Options:
What do I have to change to use a 9v battery in this circuit? Answered
This is the light theremin from Make Projects http://makezine.com/projects/light-theremin/
It uses 4 AA batteries, so 6 volts.  Can I use a 9 volt battery instead?  If so, what would need to be changed in the circuit?
Josehf Murchison
Josehf Murchison
7 years ago
If you are making a theremin change nothing other than the battery holder of course, just remember these work best indoors with a single light source.
tgferreira184
tgferreira184
7 years ago
there is no problem about the battery holder:
https://www.instructables.com/tag/type-id/?sort=none&q=battery+holder
mpilchfamily
mpilchfamily
7 years ago
Nothing. The 555 timer should be able to take up to 16V.
mpilchfamily
mpilchfamily
Answer 7 years ago
BTW the 4x AA batteries will last longer then a conventional 9V battery.
rachl009
rachl009
Answer 7 years ago
Thank you!
Do you know about how much longer? I just wanted to use a 9v because I already have a clip/holder for it and don't have one for 4 AAs
verence
verence
Answer 7 years ago
An AA cell has a volume of ca. 7.5cm³ for 6 cells that would be 45cm³, a 9V block has a volume of ca. 13cm³. So the 6 AA cells should last about three times as long as the 9V block - given the same chemistry and quality.
rickharris
rickharris
Answer 7 years ago
You can get a battery holder for the AA's which uses the same battery clip as a 9 volt PP9
mpilchfamily
mpilchfamily
Answer 7 years ago
Just making sure you where not under the impression that a 9V battery would be a better option here.
A 9V battery only carries .55 Ah while a single AA has about 2.4 Ah in it.
A battery’s amp-hour rating indicates the total amount of energy it will deliver at a constant rate of discharge over a period of 20 hours before it reaches a voltage at which it is stone dead for all practical purposes.
Read more: http://www.answers.com/topic/amp-hour-ratings#ixzz2XI4oRK3e
iceng
iceng
Answer 7 years ago
+1
verence
verence
Answer 7 years ago
Whoops? Why didn't I see your answer before I replied? You're correct, of course.
verence
verence
7 years ago
Didn't check it completely, but it should work. Just connect the battery and try. It will not break anything, that's for sure - the 555 can work with even high voltages.
