127Views4Replies
Author Options:
What flexible rubber can i use that will stick to ceramic to make it shock proof? Answered
when the ceramic is broken it does not fall apart completely because its bonded with rubber
RavingMadStudios
RavingMadStudios
11 years ago
You don't say what kind of ceramic or what shape, or what kind of shock, so it's hard to specify a solution since I'm not sure what the problem is.
That said, all of the solutions you've received so far are good ones. You could also possibly just make a sleeve for the ceramic bit out of an old sock or a nylon stocking, or spandex,
Re-design
Re-design
11 years ago
Silicone in a tube works very well for this.
orksecurity
orksecurity
11 years ago
I'd try the plastic dip compounds used to cushion and insulate tool handles. Some hardware stores stock the stuff; it's available under several brand names.
jeff-o
jeff-o
11 years ago
Don't limit yourself to rubber!  Any number of textiles will provide that function as well.  A piece of fabric (synthetic or natural) glued to the tile should hold it together nicely, and on top of that it's thinner, cheaper, easier to use, and likely "greener" as well.
