183Views2Replies
Author Options:
What for are these connectors on (older) Arduinos? Answered
On Arduino Duemilanove and some other boards (but not on Arduino Uno) there are four small plates near usb socket, numbered 4 3 2 1. On official photos they are just plates, but on my Hong Kong board there are male header pins instead. They are not mentioned in general texts about the board and I can't seem to know the right phrase to successfulli google it.
What are these four connections for?
Tags:arduino
frollard
frollard
Best Answer 9 years ago
http://arduino.cc/en/Main/ArduinoBoardDuemilanove
There are links for schematics there;
http://arduino.cc/en/uploads/Main/arduino-duemilanove-schematic.pdf
Which shows those pads coming directly off the FTDI serial chip, header X3.
1CTS
2DSR
3DTD
4RI
From the ftdi datasheet:
"Pin No. Name Type Description
TXD
Output
Transmit Asynchronous Data Output.
DTR#
Output
Data Terminal Ready Control Output / Handshake Signal.
RTS#
Output
Request to Send Control Output / Handshake Signal.
5
RXD
Input
Receiving Asynchronous Data Input.
6
RI#
Input
Ring Indicator Control Input. When remote wake up is enabled in the internal EEPROM taking RI# low (20ms active low pulse) can be used to resume the PC USB host controller from suspend.
9
DSR#
Input
Data Set Ready Control Input / Handshake Signal.
10
DCD#
Input
Data Carrier Detect Control Input.
11
CTS#
Input
Clear To Send Control Input / Handshake Signal.
12
CBUS4
I/O
Configurable CBUS output only Pin. Function of this pin is configured in the device internal EEPROM. Factory default configuration is SLEEP#. See CBUS Signal Options, Table 3.9.
13
CBUS2
I/O
Configurable CBUS I/O Pin. Function of this pin is configured in the device internal EEPROM. Factory default configuration is TXDEN. See CBUS Signal Options, Table 3.9."
Basically, functions on the ftdi chip that 99% of people will never need/use. Since the new duinos don't use the chip, they don't get included on newer boards.
iceng
iceng
Answer 9 years ago
+1
