3Views2Replies
Author Options:
What if no separate ground wire in plug? Answered
I'm in the US and, generally speaking, comfortable with the AC wiring of my house. At the wall outlet, black is hot, white is neutral, and green (or bare copper) is ground. As preliminaries for this class, I am building a variable power switch for my soldering iron, using a standard metal box, standard electrical receptacle, and a slider switch. If I connect the switch-and-receptacle-in-a-metal-box to the wall using a cord with only 2 prongs (i.e. no ground prong for the wall), do you see a problem connecting the ground to neutral in the metal box holding the receptacle & sliding switch? Since all the ground and neutral wires connect to the same bus inside the main panel on the side of my house, I can't imagine why connecting the ground and neutral earlier, in the metal box, would be a problem.
... Come to think of it, I generally followed the locally approved practice of having up to 3 circuits use the same neutral wire, and up to 3 circuits use the same ground wire. I don't know if that would make a difference.
Jimbo724
13 days ago
I found a 3-prong power cord. (It turns out I have many saved from obsolete computers over the years; I forgot about that box.) Although I no longer "need" an answer to my original Q, it nonetheless would be interesting to know the answer, and whether something similar would apply to DC electronic circuits (although the different nomenclature and wire colors in DC electronics make it hard to imagine how I could even ask the same Q in the DC context; AC and DC are so different).
