134Views5Replies
What is a moldable material that can be drilled into?
Hi all,
I'm a student working on a project, and i've run into a bit of a problem finding a material such as an epoxy or resin that can be molded to fit a groove, and be drilled into once dry. I have a plastic rim that I would like to fill in the grove where the inner tube would normally be.
https://engineering.purdue.edu/ece477/Archive/2008/Spring/S08-Grp12/pics/Wheel01.jpg
This picture is similar to the rim we have.
If anyone has any suggestions, they would be greatly appreciated.
4 years ago
Shape lock (polymorph in the Uk)
Answer 4 years ago
Also called InstaMorph: https://www.amazon.com/gp/product/B003QKLJKQ
4 years ago
It looks to me like fibreglass re-inforced plastic, so literally everything will stick to it.
Costwise I would opt for a fibreglss resin with shredded fibreglass as a filler for added strength.
Creating a very rough surface first using coarse sandpaper or similar will help to increase bonding strength.
4 years ago
A hand moldable plastic.
Click pic to see all...
4 years ago
Use a two-pack epoxy, add a thixotropic additive, to make it stick in the groove.
Epoxy doesn't DRY, it CURES.
