396Views8Replies
Author Options:
What is a simple indicator for use inside the house to show if a circuit breaker in my garage has tripped? Answered
The refrigerator in my garage has tripped the circuit breaker several times without my knowledge, spoiling my food. Without actually going into the garage, how can I tell if the breaker has tripped, using something such as an led or buzzer? I could hear a loud buzzer in the garage.
Burf
Burf
Best Answer 10 years ago
Get a failed circuit alarm. Plug it into the same circuit as the freezer and if the circuit fails, a loud buzzer sounds. Most of them require a 9 volt battery.
frollard
frollard
Answer 10 years ago
Seconded. If you can't find one, then get a 12 volt relay, and a 12 volt wall-wart power adapter. Plug it in on the same circuit as the fridge. Hook up a buzzer on batteries to the 'normally closed' on the relay so that when power fails it sounds the buzzer.
jaxboy
jaxboy
10 years ago
Thanks for the help! I am ordering a relay, wall-wart and buzzer. I might just run long wires to the buzzer and put it in the house. I will hear it for sure then!
jaxboy
jaxboy
10 years ago
I have a small freezer and a medium-sized refrigerator plugged in to the only outlet. I think the breaker trips when both compressors happen to be cycling on at the same time. The breaker (in a rented house) is a lower wattage than I would like, but I'm stuck with this situation.
steveastrouk
steveastrouk
Answer 10 years ago
What's the breaker rated at ?
steveastrouk
steveastrouk
10 years ago
How about a cheap wallwart, say 3V out, and an LED in the garage wall you can see from in the house ? No LED, No fridge.
I'm with L. though you MUST find out WHY its tripping. Is the garage on a GFI ? Do you KNOW its the fridge tripping it ? Get a licensed electrician to test the refrigerator for ground leakage.
Is the compressor getting hot ?
Steve
lemonie
lemonie
10 years ago
'Fridges shouldn't do this.
You should find out why and fix that.
Is it old, sitting in a puddle, rusty, inadequately ventilated around the radator etc?
L
