95Views4Replies
What is making my sprayer drip?
I've replaced all the O rings, so now the only drip is in the spray. About 1/3 of the cone of spray just sprays crazy and dribbles from the hole in the top of the domed piece that screws on. The hole looks round to me. I can't tell if the inside of the dome is uneven.... it's pretty small and dark in there. I've cleaned it with Barkeeper's Friend on a Q-tip, but there is still some staining. If the problem is inside, how would I smooth it out?
If the problem is in the male part, what should I be looking for that might cause this?
9 years ago
Could be a hairline fracture in that part that expands with the pressure inside the sprayer.
9 years ago
Could be some meneral build up from the water. Soak it in some vinager to loosen it up and try to use a Qtip.
Answer 9 years ago
Thank you for your thought on the problem. Usually vinegar works - especially in hard water areas, but sadly it has had no effect.
Answer 9 years ago
+1
