933Views18Replies
Author Options:
What is the best way to clean excess solder from a wire tip? Answered
At school we do electronics, and i soldered some wires together and now there is a large blob of solder on the end, and nothing to attach wires to because the wire fell off. There is now no wire left. Help!
Koil_1
Koil_1
Best Answer 12 years ago
Get yourself some sort of a catch tray. Preferably something metal. While your soldering the wire simply let it flick downward and the excess solder should fly away onto the catch tray. If it's a relatively sensitive connection just make sure you have enough flux/rosin on it and dab the soldering iron to the bottom of the connection. The excess solder should flow off onto the iron leaving it clean. Note that if it's not shiny anymore, it needs more rosin to clean the metal's surface. Oxidization is the biggest cause of the blobs of excess solder.
The Jamalam
The Jamalam
Answer 12 years ago
it worked! Thanks a lot!
jeff-o
jeff-o
Answer 12 years ago
This should work fine (wear eye protection!) - otherwise use something called solder wick (or solder braid). It is designed to wick up solder (thus the name).
The Jamalam
The Jamalam
Answer 12 years ago
ok, you do that. I'll do things that mental assylum people dont do
I_am_Canadian
I_am_Canadian
Answer 12 years ago
Some people just cant take a joke...
The Jamalam
The Jamalam
Answer 12 years ago
obviously you can't lol
junits15
junits15
12 years ago
I am a little confused by your question. do you mean that there is no copper showing? or do you mean that there is a blob of solder in the way of what you are doing?
The Jamalam
The Jamalam
Answer 12 years ago
well, after the massive blob appeared, it a coats the entire stripped end of my wire and on top of that, the wire i soldered to it fell off.
junits15
junits15
Answer 12 years ago
so one good thing is that it is coating the wire that usually is good news because it makes the wire more acceptant to solder. Although it sounds like you heated the solder to long and boiled all the flux away, does the solder have a rough finish to it? The flux is what cleans the oxidation from the metal being soldered, oxidation prevents the solder from sticking. You can tell if the flux is gone if there is no more smoke coming from the joint.
Sandisk1duo
Sandisk1duo
12 years ago
just hit it on the table, the solder should roll off
deathpanda
deathpanda
12 years ago
i use a vacuum de-soldering tool i got it from radio shack for 10 bucks.(witch means you can get it on ebay for 3). there great they are reusable, they don't fling solder around or burn your hand. and they are great for getting solder off small parts like ic's because they don't spread out like de-soldering braids
deathpanda
deathpanda
Answer 12 years ago
as koil said you might want to make sure you are using the right technique to solder. you need to use the right amount of rosin and also you should be heating the wire and applying the solder to the opposite side of the wire that the iron is on not the same side or to the iron it self. if your having trouble there's a bunch of good soldering ables.
thompind
thompind
12 years ago
Heat the solder on the end of your wire until it is fluid then wipe it on a wet sponge!
KentsOkay
KentsOkay
12 years ago
Use your iron to melt the solder, than scrape/blob away with a popsicle stick
