2682Views11Replies
Author Options:
What is the best way to cut a rubber (non-steel-belted) tire? Answered
I need a method of cutting a non-belted rubber tire (I'm attempting to sole shoes) that will (a) allow for an angular design, and (b), leave relatively clean edges. The best idea I've gotten was to use a hacksaw with water in the cuts for lubrication, but the results are too ragged and uneven. Any good ideas would be appreciated!
kelseymh
kelseymh
Best Answer 11 years ago
I use a bandsaw. To reduce the ragged edges, I put the tire between two pieces of scrap plywood (1/4").
o-diskordia
o-diskordia
Answer 11 years ago
Oh, criminy, that's not a bad idea... dunno why I hadn't considered using the bandsaw before; I'd imagine that's the last time I'd end up using that blade, but that's much easier than trying a Sawzall or hacksaw. I'll have to give this a shot- thanks!
kelseymh
kelseymh
Answer 11 years ago
It's actually not as bad on the blade as you might think. If you cut slowly (don't push the piece through), you'll end up with rubber "chunks" that you can get off the blade with a wire brush. Now, cutting a steel-belted tire, that's a real mess.
steveastrouk
steveastrouk
Answer 11 years ago
Smoky job, but an angle grinder works well. Steve
kelseymh
kelseymh
Answer 11 years ago
P.S. You should post this as a top-level comment. Comments within threads are not identified by the database as "Answers".
kelseymh
kelseymh
Answer 11 years ago
Nice option! Especially for someone who might not have a bandsaw at home. Are you able to get precise cuts?
steveastrouk
steveastrouk
11 years ago
Try an angle grinder. It takes a bit of practice, but you can cut windows in the things with some practice ! Use a "cutting disc" not a grinding disc
IvanC200
IvanC200
Reply 1 year ago
What type of blade did you use
steveastrouk
steveastrouk
Reply 1 year ago
One of the 1.5mm cutting disks
AnotherBrian
AnotherBrian
11 years ago
I've never tried it, but Tin snips might work if the rubber is thin enough to fit in the jaws. Long handled pruning shears might work too.
and7barton
and7barton
11 years ago
Even a plain old-fashioned hacksaw does the job.
