20094Views5Replies
Author Options:
What is the difference between Vcc- and ground? Answered
What is the difference between Vcc- and the ground symbol on this schematic? Or are they the same thing? I've just never encountered this before.
Fixya
Fixya
8 years ago
Thanks you all for those info.
Wickedweed
Wickedweed
9 years ago
Ground is relative. Imagine connecting two 9v batteries 'in' series and you make the joining point the ground. One pole of the battery will be +9v n the other will be -9v with reference to the ground
orksecurity
orksecurity
9 years ago
Another way to think of it: Ground is the reference point relative to which other voltages in the circuit are measured. Vcc- is negative relative to ground, Vcc+ is positive relative to ground. We usually call the ground "zero volts", to make the other measurements simpler.
AndyGadget
AndyGadget
9 years ago
That's an amplifier which has positive and negative voltage rails, for example +12V and -12V, with reference to Gnd (0V).  The PSU to provide this is called a split-rail supply, which has a positive and a negative voltage regulator.
frollard
frollard
Answer 9 years ago
+1. Ground doesn't necessarily mean negative, just 'zero', capable of sourcing or sinking current.
