92Views4Replies
Author Options:
What is the fix? Answered
I see this kind of error fairly often.  NOT DECLARED.
This example is from the Arduino web   sitehttp://arduino.cc/en/Tutorial/MouseContinuousDrawing
I
s there some rule to follow to fix these errors?
Tags:Arduion
WWC
WWC
8 years ago
Found out,
This a Leonardo sketch only. I guess not compatible with other Arduino's.
mpilchfamily
mpilchfamily
Answer 8 years ago
Thats correct. The older Arduinos don't have built in Mouse and Keyboard functionality. The new Arduinos use a different USB interface chip which give it native mouse and keyboard functionality.
Jayefuu
Jayefuu
8 years ago
This one is simpler and calls the same function. Do you get the same problem when running this?
http://arduino.cc/en/Reference/MouseMove
What hardware are you using? What version of the Arduino IDE?
WWC
WWC
Answer 8 years ago
Yes same problem in 23 and 1.0.
Do you get an error if you run it?
I will down load the latest IDE and give it a try.
I have not built this yet, only check if it will compile first. If that's what you mean by hardware.
