you should try obtaining pure hydrogen. all you have to do is do electrolysis on water or mix any metal with an acid and put a cover on it. remember though that gases pour upside down. they behave exactly like liquids except upside down and most gases are invisible. hydrogen is extremely explosive though so watch it.
When I moved to MN I immediately met a neighbor who was jealous of my patio location. Third floor directly across from Mall of America. Day after I moved in he moved a small cannon onto my patio and launched from time to time. He used rubbing alcohol and suntan lotion spray and it was loud and crazy. He hit the 'M' on the Macy's sign then started aiming over a highway and I tossed him out.
Lol... Funniest shah. I've read so far... So we already had one made with a marrihawana capsule... Due to stoned sponge minds and heavy weed intake we decided to phuckn play... Excuse my lango. I like ... I mean I LOVE MANGOS... SO ANYWAYS... WE DONT HAVE HAIRSPRAY OR STUFF... CAN WE USE ... FOR SAY CLINQUE HAPPY PERFUME? I WAS THINKING OF COATING THE INNER LAYER OF THE CAPSULE WITH PETROLEUM JELLY THEN SPRAYING.????!!!! STONE
I've noticed that axe gets mentioned a lot and it does do a great sometimes too great I had an experience with it and some oxygen where I used an oxygen tank to blow out my chamber and one very small spray of axe and it literally turned a great gun into dust to this day I have only found 3 very small pieces and one of those pieces came from my nasal cavity after it went through my cheek bone and eventually had come out in my throat Also from my cheek to my jaw had a brand new opening in the form of a flap not to mention how happy my mother was when she had found out all the stucco from our porch was now on the ground so with that just be mindful of everything you test because I absolutely new better but during conversation with a friend I absentmindedly did something that should have killed the both of us without doubt BUT DON'T STOP HAVING FUN JUST LEARN FROM MY MISTAKES WITHOUT MAKING THEM YOURSELF CAUSE I HURT LIKE HELL ¡¡¡
Oxygen acetylene... use a cutting torch get i nice neutral flame and put it out on your boot. Give i i nice 3 to 4 seconds in the chamber. Works real real well you get a nice sonic crack with nothing in the barrel! Also had a real nice big blue flame!
Rubbing alcohol (ethanol) is cheap and works well, BUT buy the 90 or 91% (not the 70%). About 4 spritzes from an atomizer bottle will launch a 2" plug more than 100 yards. ALSO: Warming up your potato gun before you fire it helps vaporize whatever you spray into it. With the endcap off, I spray 3-4 spritzes into the combustion chamber and light it with a match. When it burns off, the chamber is warm and you're ready to load and launch.
A friend of mine uses that spray-air freshener crap. Double purpose: Makes one good boom, and keeps the gun smelling like cheap flowers (overspray down the side)
rickman has it! engine starting fluid = diethyl ether. go for the premium grade starting fluid, as it is 40-60% diethyl ether, whereas the regular grade is about 20-35%. its about 3 bucks a can
Best Answer 11 years ago
now i know im late getting to ya on this- but i use propane, or brakleen
BRAKLEEN IS EPIC!!
1 year ago
lol you have to try to obtaine pure hydrogen it works ive try it before
1 year ago
Have had the same problem. AXE BODY SPRAY works the most consistently for me
1 year ago
Carbide + H20
12 years ago
Oh,my mom bought a can of furniture polish for a dollar and it says extremely flammable.
Reply 1 year ago
Did you light 'er up???
11 years ago
Reply 1 year ago
What could happen???
1 year ago
1 year ago
1 year ago
1 year ago
Also hydrogen works great you can make it easy by mixing aluminum foil and liquid plumber and let expand for about 30 seconds before igniteing
3 years ago
I played with Bodyspray and burned my finger
11 years ago
continuous spray sunscreen
Answer 4 years ago
extremly flam
12 years ago
Cheap aerosol hairspray or wd40 works best.But hairspray gums up the chamber.
Answer 4 years ago
not sun skreen
6 years ago
6 years ago
amm so the hairspray with the tallest concentration of these compounds
7 years ago
8 years ago
I think acetylene and propane work good
10 years ago
i am trying to build a double barol potato gun and try to find something new to use s the fuel
try these
axe for men spray
pam
hair spray
bug spray
11 years ago
Ether used to start diesel engines
11 years ago
buy rubbing alcohol and put it in a spritzer bottle.
11 years ago
You can also try the shoe spray (that makes shoes water proof) it works well
11 years ago
TAG or AXE deoderant spray works wonderful better then ether.
11 years ago
11 years ago
use some kind of hairspray with the potato soaked in ether it will alot farther then just hairspray
11 years ago
Don't try hairspray. It doesn't expand fast enough.
12 years ago
12 years ago
I would try carb cleaner or starting fluid available at any auto parts store. You get a lot of bang for your buck.
12 years ago
try 20%+ RC fuel or right guard
12 years ago
or instead of aerosol you might try hand sanatizer
