burning something is combining a fuel with oxygen. If you burn a hydrocarbon, you get water (hydrogen and oxygen) and carbon dioxide (carbon and oxygen). If you burn hydrogen gas (H2) then you get 2 H2 + O2 --> 2 H20. H20 is ...water...and you have a balanced equation, so there are no other products. Homework? Since it is exothermic, and the output is water, you are likely to end up with hot...water...or steam :)
Sure does -- Like they say, if you get air 'hot' in any reaction, its not just oxygen -- its got a bunch of nitrogen, neon, xenon, and other fun gasses -- most of them don't react, because the hydrogen and oxygen are really happy to mingle, but a few do - thus you end up with trace amounts of other stuff. Similarly, if you burn propane in a controlled setting you get ideally: (C3H8 + 5 O2 >> 4 H2O + 3 CO2 + heat). If you do it in air you get nitrogen (N2) forming a few extra chemicals...
. Yep. In a "perfect" reaction 2H2 + O2 -> 2H2O + heat . As steveastrouk points out, in the real world, there will be other components, but water will be the main one.
The name is derived from the Greek hudro meaning water, and -gen also from the Greek genes meaning to be born / become. Hence Hydrogen means "water-creator".
Best Answer 10 years ago
Answer 10 years ago
so if hydrogen justs burns i still get steam? (not homework, just a project.)
Answer 10 years ago
Answer 10 years ago
Actully im going to vacuum out all the air in a tank and then fill the tank 1/4 full of hydrogen and than make a spark in there. What will it produce?
Answer 10 years ago
Assuming there is also some oxygen in there: an explosion.
Answer 10 years ago
Are you sure that's not homework?
Answer 10 years ago
ya, its a project for a fusion reactor. (plus it still summer) :P
Answer 10 years ago
Nothing: It needs oxygen. Hydrogen doesn't burn without it. Anything more than 5% hydrogen in air will explode with a spark ignition.
Answer 10 years ago
4 years ago
10 years ago
Uh, mostly HEAT.
10 years ago
L
10 years ago
Dihydrogen monoxide.
10 years ago
Except if you burn in air, you get some nitrous compounds too apparently.
