3530Views13Replies
Author Options:
What kind of non-sparking ball mill media can I use other than lead? Answered
I want to make a ball mill but I can't find any lead fishing sinkers (they're bad for the environment so nobody sells them anymore). Is there anything else I can use to grind chemicals in a ball mill that won't create sparks?
coolpizzadude
coolpizzadude
10 years ago
Penny's and marbles is what I always use.
gearhead1951
gearhead1951
10 years ago
non-lead "sinkers" are made of zinc , and copper-nickel alloys are as hard as steel but still non sparking !
I know this 'cause I am a retired US Navy engineer and did a LOT of repair work on submarines !
Prfesser
Prfesser
10 years ago
Some types of ceramic media are *said* to be nonsparking.  I would not bet my life on it.  Bronze is hard enough for milling and does not spark.  Brass is somewhat softer; it will work though.  Copper is too soft and will probably contaminate the mixture being milled (lead does so too).
Be sure to run the mill outside, at least a hundred feet from anything that could be damaged by the explosion of several pounds of <whatever you are milling>.  Plug in using an extension cord, remotely.  Be safe!
orksecurity
orksecurity
10 years ago
I know ceramic media have been used in ball mills when the goal is to clean/polish larger pieces (rough castings, for example); I have no idea whether they would work for this purpose.
Kiteman
Kiteman
10 years ago
Brass - I worked in a paint factory for a short while, and all the exposed metal in the areas that handled explosive solvents were made of brass because it doesn't spark.
Failing that, you can get lead-free sinkers. I don't know what they are made of, but they feel soft enough to be sparkless.
steveastrouk
steveastrouk
Answer 10 years ago
Brass balls can be found near cold monkeys.
Kiteman
Kiteman
Answer 10 years ago
>groan<
nickodemus
nickodemus
10 years ago
Depending on what your location is, you should still be able to get lead sinkers, I certainly can in my hillbilly area.
Ke-Bob
Ke-Bob
Answer 10 years ago
Won't those make sparks when they bump into each other though? I'm going to be milling explosive chemicals so I have to be sure that the milling media won't blow everything up.
steveastrouk
steveastrouk
Answer 10 years ago
No, you can't get sparks off copper and bronze. Traditionally wood was used in explosive milling if I remember correctly.
Re-design
Re-design
Answer 10 years ago
Copper and bronze are not hard enough to create a spark.
