116Views6Replies
What kinds of machines/tools are used to mass produce BULLETIN BOARDS mostly CORK used.
Want to manufacture BULLETIN BOARDS
Mostly using CORK.
Any guidance
Thanks
Mostly using CORK.
Any guidance
Thanks
11 years ago
Generally, industrial carpentry tools, cork is, after all, just wood. But, more specifically, it depends on the frame you intend to mount the cork in; aluminum, steel, plastic or wood. Also whether or not you plan to do your own extrusion, bending, injection or vacuum forming is a factor, as each requires more specialized tools than used for simple wooden frames.
Answer 5 years ago
Thank you
11 years ago
I'd say "cutters" mainly. There's probably some manual assembly with glue / a staple-gun?
L
Answer 5 years ago
Thank you
11 years ago
You can contact a machine shop that is capable of making a machine that will meet your needs.
You can order all the products and set up your own factory and do it all essentially by hand.
However, it's unwise to invest a lot of capital into something that others are already doing, so it's wisest to contact a factory that's already making cork boards and place an order unless you have a radical new design that will change the face of cork boards as we know it.
Answer 5 years ago
Thank you
