380Views9Replies
Author Options:
What needs to be considered before buying a wood lathe? Answered
I am thinking of investing on a wood lathe. I have seen a few lathes of different sizes. I would like to turn bowls, dishes, chalice and even mortars out of wood. What should I need to look for on a lathe? It is size important? Thank you very much once again! You are the best!
steveastrouk
steveastrouk
Best Answer 8 years ago
Most times, it seems to me, maximum turning diameter matters most, thence motor capacity.
steveastrouk
steveastrouk
8 years ago
Yes, you don't seem to have a yen to make stair spindles or lamp standards ! I've seen some MONSTROUS bowl turning lathes, that'd have your hands off if you approached the work wrong.
blkhawk
blkhawk
Answer 8 years ago
Thank you for the warning! I'll try not to go over my head. I am thinking on a Harbor Freight lathe to start.
Re-design
Re-design
Answer 8 years ago
I've seen that lathe and don't consider adiquate. the rails are made fo hollow tubing and will flex during use.
I bought this one because it's gear box was stronger and has cast iron rails that won't flex.
blkhawk
blkhawk
Answer 8 years ago
Thank you for the info!
rimar2000
rimar2000
8 years ago
IMHO, the power of the motor is a capital matter. Then, length and diameter must fit your needs.
blkhawk
blkhawk
Answer 8 years ago
Thank you Don Osvaldo!
iceng
iceng
8 years ago
First a compressor, now a lathe for wood ?
Even with a Big size lathe, you cannot make wood or plastic
survive as a pressure tank.
Only good thing is it it will float ( teak is no longer available:-)
A
blkhawk
blkhawk
Answer 8 years ago
He, he, he! I am spending money without my significant other's knowledge. I'm getting over my "tools allowance"!
