1742Views10Replies
Author Options:
What potentiometer to use as audio control in car stereo? Answered
Hello all
I am working on installing a tablet into my car instead of the original head unit. But since the tablet will be permanently mounted inside the dash, I have no way of turning the volume up or down on the tablet, therefore I need to install a potentiometer into the audio cable that goes into my amplifier.
I have tried with a dual LIN 100kOhm potentiometer, which worked to an extend, but not as well as I had hoped.
It did turn the volume up and down, but it couldn't turn the volume all the way down as I had hoped it would be able to.
I just want it to be able to turn up quite loud, but also turn all the way down, so I don't have to pause the music everytime I want it to be quiet.
Cheers!
Mathew
Josehf Murchison
Josehf Murchison
2 years ago
How did you wire in the pot 1. 2. or 3.
Click on the Image to see all three.
Mat_Holm
Mat_Holm
Answer 2 years ago
I'm not 100% sure, as I have used this for reference as to how to wire it.
iceng
iceng
Answer 2 years ago
If shield is signal ground input then it will work..
If shield is chassis connect and signal ground is different then it won't work !
Josehf Murchison
Josehf Murchison
Answer 2 years ago
OK so you have 3 wires from your tablet.
One wire should go to ground.
The other two should go to channel a signal and channel b signal.
Channel a shield and channel b shield should go to ground.
Then the two inside pins should go to to the amp with a ground wire.
Like this schematic with three wires from the tablet and three wires going to the Amp.
iceng
iceng
Answer 2 years ago
Sounds like a variation of # 1, because Mat said
he "couldn't turn the volume all the way down"..
Josehf Murchison
Josehf Murchison
Answer 2 years ago
That's what I was thinking also.
iceng
iceng
2 years ago
+1 to each D. J. S.
The way to get noisy turn static out of a used pot is to drop a bit of CarbonTetraChloride fluid into the wiper track of the pot, is all that I can add.
steveastrouk
steveastrouk
2 years ago
You need a LOG or audio taper pot as a volume control.
Jack A Lopez
Jack A Lopez
2 years ago
The phrase is, "worked to an extent". "extent" is a noun. "extend" is a verb.
Anyway, the signal coming out of your tablet is probably intended for driving headphones, and there exist potentiometers for attenuating headphone audio.
Some headphones come with a little thumb wheel potentiometer built into a little plastic bulge in one part of the headphone cable itself.
This instructable,
https://www.instructables.com/id/Universal-EarbudH...
considers a few different ways to wire a potentiometer, volume control knob, into a headphone cable.
By the way, if all you want is to know is the size (in ohms), and character (linear taper, or log taper) of this kind of potentiometer, I think I have a few of these heaphone-cable-lump style pots, in my box of dumpster-scavenged, broken headphones.
Upon request, I can put the multimeter probes on, one or more, of these, for to give you some numbers about their electrical characteristics.
Downunder35m
Downunder35m
2 years ago
Use a potentiometer with build in switch ;)
Getting hard to find these days but were and still are used in small analog and portable radios...
