604Views3Replies
Author Options:
What sensor is best to use to measure smoke density via Arduino? Answered
I have built a cold-smoker for smoking things like bacon, cheese and seafood. Smoke is produced by burning oak chips in an old fire extinguisher and (using the air supply from a compressor) blown into an old fridge in which the food hangs or is placed on racks. Excess smoke exhausts through a second pipe at the top of the fridge. I log temperatures inside the fridge using an arduino.
For the best results the smoke density needs to be low but steady over a period of several hours. I currently control this by hand using a valve on the feed from the compressor. I'm working on controlling this valve automatically using a stepper motor to adjust the increase and decrease the airflow to maintain the correct smoke density.
How can I sense the density of the smoke reliably? I need to sense levels of density rather than just its presence. The smoke carries tars so the sensor must be easily cleanable.
Any suggestions very welcome!
Henmarsh
Henmarsh
Answer 3 years ago
Thanks for looking randofo. I did find that article but was concerned that the mesh would soon clog as the result of exposure to the sticky tar in the smoke (and there's a lot of it!). I was wondering if there might be a viable optical solution (reflected laser or IR perhaps?) that would be easier to clean/less vulnerable to degradation, even if it required more than a single packaged component.
randofo
randofo
Answer 3 years ago
You can get sockets for that type of sensor and just swap them out over time. They typically don't cost much.
Anyhow... I imagine you could get some sort LED, and put some sort of light sensor behind a translucent or semi-translucent cover. Then you can measure the decrease in light. It would take some trial and error to figure out which are the correct sensor readings.
