What sensor should I use to sense the distance of an unknown object?
Hello,
I'm trying to put together a project for the first time with an arduino uno board.
The aim of my project is to sense the distance/position/proximity of ANY object away from my sensor (board). Ideally, I want a system that is able to give good reading if the system is operating out-doors. The entire system is housed inside a box with only the power line coming out of it. The cost of the system should be cheap enough for a small, hobby project. The range of the sensor should be about 2cm to 3m.
I've looked at IR, ultrasound, and hall-effect sensors. They're not really what I need because
1. IR sensor doesn't work well out-doors
2. Ultrasound sensor has to be exposed outside of a container to send out the sound waves.
3. Hall-effect sensor needs the object being detected to have a magnet attached to it.
So are there other options I can go with?? A different kind of magnetic sensor where if the magnetic field it produced was disrupted by an unknown object, the sensor can give me back a distance reading of that object?
Best Answer 8 years ago
+1 If you have rejected the obvious.
You don't specify the range you need to work at but:
IR works quite well outdoors especially if you encode the signal. your Tv remote works pretty well doesn't it? try it out doors you won't find a lot of change.
US need not be fragile - many cars have US reversing sensors these days the system works well up to about 7 or 8 mtrs.
magnetics only work with metallic objects.
Alternatives:
Radar.
lasers
Pressure sensors
Capacitive proximity detectors
You can look these up easily.
Answer 8 years ago
I think radar is something i could look into.
Answer 8 years ago
My range is around 2cm to 3m.
Well the IR work fine if it had to be placed inside like a box? does that interfere with the signal?
Answer 8 years ago
glass window!
Answer 8 years ago
Glass, or perspex ? One of them blocks IR from LEDs.
8 years ago
Capacitance can be made to work over several metres - in WWII it was used as a method of measuring aircraft height, with great accuracy, up to about 6000 feet.
8 years ago
Tape measure.
Answer 8 years ago
+1
